Temperature Guage
Old 03-29-2006, 05:34 PM
Audi90C's Avatar
Default Temperature Guage
The light on my guages flashes for the first 5 mins of my car running. Its the Upper left light and its looks at if its flashing the temperature indicator. It usually only flashes when the steering wheel is turning and I've checked for coolent and its full, any ideas? thanks! I've got a 94' Audi 90
Old 04-02-2006, 04:24 AM
msa10's Avatar
Default RE: Temperature Guage
I don't know but could it be a bad thermostat?
Old 04-02-2006, 09:51 AM
BadLuckAudi's Avatar
yea Id check the thermostat
Old 04-02-2006, 11:36 AM
strange it should only do it when turning the steering wheel are you sure its the temp gauge and not the power steering fluid just a thought also a code would be there for the stat P0116
Old 04-02-2006, 11:02 PM
Audi90C's Avatar
Yea its certainly not the power steering, I've checked that level everytime. Just the other day its did it once while the wheel was straight, but it hasn't done it since and still contiunes to everytime the wheels is turned. Is it possible there are some electronics in the wheel that might effect it in some way? Thanks!
Old 06-01-2006, 01:32 PM
cabrioman1995's Avatar
Where is the thermostat located? Is it relatively easy to get to?
Thanks
Old 06-01-2006, 08:38 PM
InExile's Avatar
Check the wires, the harnesses for broken wires or shorts, or the coolant level sender
jdkluck
04-27-2009 02:26 AM
expresse9
09-30-2008 01:06 AM
hannya3
06-15-2007 12:55 PM
errol619sd
04-24-2006 01:38 AM
ram
03-06-2006 02:36 PM
Quick Reply: Temperature Guage
