AudiForums.com
Go Back   AudiForums.com > Audi Models > Allroad Model Line
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read ExperienceGarageUsed CarsVendors TSBs
Search
Welcome to AudiForums.com
Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Reply
LinkBack Thread Tools Search this Thread
Old 06-30-2010, 05:09 PM
caseydog's Avatar
Default 2005 allroad RR tire wear...
Basics: 2004 allroad with 57,000 miles. Well maintained, no wrecks.
When I last replaced tires, the right rear on the old tires was worn WAY more than the other three. I bought new tires, and had a proper four wheel alignment done on the car.
5,000 miles later, the right rear is almost completely gone, while the other three have plenty of tread.
All four tires are wearing pretty evenly across the tread, but this one tire just wears way faster than the other three. I use Audi's recommended tire pressures, and check pressure often.
The alignment was rechecked today, and the toe was out slightly (.28 of a degree), but that seems awfully little to wear a tire out in 5,000 miles.
I also changed the rear dif oil, and the stuff that came out didn't show signs of problems in the dif.
My driving style is VERY tame in this car, so it's not something I am doing.
One suggestion is the right rear airbag/shock is failing. I have noticed my allroad is a bit skittish over bumps, with the rear end "hopping" if I hit a bump at 40-plus MPH. That would point to a shock (or shocks) on a normal car, but I don't know on the air suspension.
Is it possible for a shock to go bad without effecting the airbag? The car doesn't "sink" overnight in the garage, so the bag seems to be okay.
Another suggestion was control arm bushings.
Anyone else had this problem?
__________________
2004 allroad quattro
www.gzphoto1.com
Old 07-07-2010, 09:19 PM
caseydog's Avatar
Well, RUF Auto Centre, one of the best shops in Dallas, could not figure it out, so I took it to University Park Audi, and they had the car for three days, and could not figure it out. So, I guess I'll just have to replace RR tires every 6,000 miles.
Man, what a mystery. There has to be a reason, but everything on the car seems to be just fine.
Z
__________________
www.gzphoto1.com
Old 07-15-2010, 04:06 AM
Banned
Smile Thanks for sharing
Thanks for sharing, to learn the experience under the left. Do not leave me.All-in-one http://www.mkv-converter.biz for you. Convert MKV to any other video formats; Convert any other video formats to MKV.
Old 07-17-2010, 11:30 AM
SloRide's Avatar
Points: 4,647, Level: 43
Points: 4,647, Level: 43 Points: 4,647, Level: 43 Points: 4,647, Level: 43
Level up: 49%, 103 Points needed
Level up: 49% Level up: 49% Level up: 49%
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
I had a similar problem with my 04 allroad. the car would pull to the right and the tires on that side were wearing faster then the left. it was aligned twice and still would pull right. the shop thought it was a bad tire. since the tires were getting worn i made the decision to get new rubber all the way around and what a differance! immediately i could feel it, the steering had a netural feel in my hands and it did not pull to the right. So, there must have been something wrong with the old tires. btw...stock size is 225/55-17 but i went with a set of 235/55-17 Cooper CS-4, a little wider, taller and fill up the wheel well better.
__________________
Earth First! We'll ride the other planets later.
Old 07-18-2010, 03:09 PM
caseydog's Avatar
I don't have any "pull" in my car, and it's just one tire that repeatedly wears faster.
BTW, I went up to a 235 size, too. It does look a little better.
Z
__________________
www.gzphoto1.com
Reply
Tags
17, 2005, 235, 55, a6, allroad, audi, change, oil, park, problem, specifications, tire, tyre, university, wear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
New Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
© Internet Brands, Inc.
Emails Backup
