04-27-2011, 10:17 AM
Points: 11,545, Level: 70 |
Level up: 74%, 105 Points needed |
Clutch worn?
Test driving a used Allroad manual, I did my 'high gear, high RPM clutch drop' (means: cruising on the interstate, push clutch, rev up, drop clutch). The clutch did NOT 'catch', instead kept slipping until I dropped to rpm to 'catch' it.
Is that a sign for a worn clutch? during normal driving, including hard launches and WOT pulls, the clutch did not slip and felt fine.
I will replace the clutch at a later stage anyway as part of turbo upgrade, but hope to drive the car first for some time.
__________________
1998 Audi A4 1.8T Quattro, dark blue, K03/K04+ hybrid, Carbonio CAI, APR Inlet Tubes, APR R1 diverter, GIAC PC16, 31lb inj, 20x6x2.75 FMIC, 185 g/s MAF flow, DP 'sport cat, Milltek CB Exh, Podi Boost Gauge, 17" OZ F1 225/45-17, PowerSlot, Hawk Pads, SB Stage III clutch; 1996 Audi A 2.8 Quattro auto, stock, 2002 AR 6 spd lower wider Stg2 cust
05-16-2011, 04:25 PM
Level up: 76%, 49 Points needed |
The usual method of testing is to put the car in the highest gear while stopped and idling, then slowly release the clutch while holding the brake. If the engine stalls, then the clutch is "serviceable" (useable).
At high rpms the motor can probably overpower the clutch....
Tags
1998, a4, audi, catch, clutch, driving, drop, laeter, modrem, push, revs, stall, test, worn, wwwaudi  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
