AudiForums.com
Go Back   AudiForums.com > Audi Models > Allroad Model Line
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read ExperienceGarageUsed CarsVendors TSBs
Search
Welcome to AudiForums.com
Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Reply
LinkBack Thread Tools Search this Thread
Old 09-08-2010, 04:41 PM
Points: 1,493, Level: 21
Points: 1,493, Level: 21 Points: 1,493, Level: 21 Points: 1,493, Level: 21
Level up: 93%, 7 Points needed
Level up: 93% Level up: 93% Level up: 93%
Daily Activity: 3.9%
Daily Activity: 3.9% Daily Activity: 3.9% Daily Activity: 3.9%
Default suspension issue
So all of the sudden I am not getting the ride height warning indicator on the dash. Everything appears to be ok, as in the height at the 4 corners seems to be correct. If the light is off the suspensions adjustment works fine. Where do I go ? What do I do about it?
Old 09-08-2010, 08:41 PM
do you mean you're not getting the warning light at start up? If all is working well then I really wouldn't worry about it. If you have a OBDII scanner it could tell you what it going on with your car.
But again if the level system is working through all 4 levels without any operational issues then you should be fine.
Old 09-08-2010, 08:54 PM
Actually what is happening is that the light is pretty much always on. This started after it rained for the first time in a few months. Every once in a while it will stay off after I start it but not usually. The car is staying level but I cannot change the level when the light is on.
Seems like I should get a scanner to see if there is an error thrown. The odd thing is that occassionally it will go off. The other thing I am thinking is hat I should check the tire pressure, as I read somewhere that could make a difference.
Thanks for any help.
Reply
Tags
allroad, audi, height, indicator, light, pressure, ride, suspension, tire, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
New Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
© Internet Brands, Inc.
Emails Backup
