Audi A2 This compact Audi A2 offers a lightweight aluminum structure which allows the small yet efficient engine to offer performance comparable to others in its class.
Temp Fluctuation
Old 10-18-2006, 11:08 AM
richpenney's Avatar
Default Temp Fluctuation
Hi Guys,
My A2 Temp gauge fluctuates between the Centre and Cold. I have changed the thermostat and it seemed to work ok for a couple of months but then the problem returned. It may be as a result of the colder weather returning and seems to be affected by the Climate control being set to warm. (My feet are freezing at any setting below 24 degrees!) Any pointers please?
Regards
Rich.
Old 10-18-2006, 02:57 PM
Default RE: Temp Fluctuation
I don't think there is a problem to be honest, when you turn the A/C on your turning a fridge on so setting it to cold cools the engine even more because the fans are on constant same as a fridge effect now when you use the A/C for heat it works the engine harder and the temp gauge will rise because its creating heat and not cold if you understand that,
don't use the A/C to get warm
Old 11-04-2006, 08:39 AM
BzeA4's Avatar
^^what he said.
Also, not sure if its on the A2 but maybe check out sensor? thats a common problem
abetz470
B7 Models
11
12-19-2022 05:50 PM
toolagit2qwit
01-29-2013 01:46 AM
My Ryde
06-10-2010 04:54 PM
cmsc07
B8 Models
01-09-2010 09:36 AM
jchaffee1
05-02-2008 02:22 AM
Quick Reply: Temp Fluctuation
