A3 Fault Code HELP! - AudiForums.com
Reply
Thread Tools Search this Thread
Old 10-06-2011, 03:44 PM
Default A3 Fault Code HELP!
Hello everyone, I have a 2006 Audi A3 completely stock and have run into some problems after my drive accross country.
I currently have these fault codes
P0507- Powertrain, RPM higher than expected
P0300- Powertrain, Random/Multiple Cylinder missfire
P0304- Powertrain, Cylinder 4 misfire
P0171- Powertrain, System too lean (bank 1)
and these next codes are pending..
P0302- Powertrain, Cylinder 2 misfire
P0303- Powertrain, Cylinder 3 misfire
Can anyone tell me what this means in terms of repair? If so how much it would cost in parts? If any other information is needed just ask and I will do my best to get it.
If it helps, I used the android app "torque" and the "pxi kiwi" OBD2 bluetooth adapter to get these codes off my ECU.
Thanks!
Reply
Thread Thread Starter Forum Replies Last Post
Fault code liamol B7 Models 0 12-05-2011 03:41 PM
Fault code cardiffkid S Car Model Line 0 10-13-2008 12:52 PM
fault code JohnnyS4 S Car Model Line 2 10-13-2008 10:02 AM
Help CEL Fault Code 299 adotjdot Audi A4 2 11-16-2007 04:48 PM
fault code, need help AudiTim Audi A4 3 08-13-2007 05:55 PM
Tags
06, 2006, a3, audi, change, code, codes, error, fauilt, fault, misfire, p0171, p0303, p0507, post, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
