audi a3 tdi 2004
P0118 is for a detected fault in the ECT circuit (engine coolant temp). Most likely cause is the ECT sensor itself before a wiring issue.
P0234 is for a detected overboost condition. Common cause of that code is the turbo actuator motor becoming seized (vacuum motor on the turbo). It's available as a separate part now vs "serviced only in turbo assy".
Of course, PROPER diagnosis needs to be done before replacing any parts. I only mentioned the most common cause of each fault code for reference. Well OK the ECT code, I'd just replace the sensor and see what happens. They're less than $25. Make sure to pick up a new o-ring seal and plastic clip for it at the same time, if not included with the sensor.
morteym
07-29-2012 06:18 AM
ludazena
04-24-2008 12:17 PM
ocrane
03-06-2007 02:02 PM
nford
11-16-2006 09:25 PM
