Engine lose power when heated
Old 07-29-2013, 12:45 PM
nikola.turkovic2's Avatar
Default Engine lose power when heated
Hello,
i have Audi A3, 1.6, 1998.
when the car is cold, goes normally. When he gets to 90 degrees Celsius, it loses power and engine not running at full power. We have already changed CKP sensor, lambda sonda,air filter,sparking plugs.. problem is still here..diagnostic says error 00513. does anybody have solution for this problem? sorry for bad english
Old 07-29-2013, 02:01 PM
sheldon's Avatar
Ross tech and google shows 00513 is the following error:
*Engine speed sensor (G28)
possible effects:
*Engine does not start
*Misfiring
*Engine cuts out
Check your speed sensor and wiring.
Old 07-29-2013, 02:41 PM
Engine speed sensor is CKP sensor,i've changed it..
Old 07-29-2013, 06:03 PM
sheldon's Avatar
Did you clear the code once changed? If you did and it came back - check the wiring.
Mhuntington
02-04-2014 02:28 PM
doogieh
06-08-2009 08:09 PM
AGreen
10-06-2008 11:10 PM
Lopster99
03-02-2007 01:58 AM
mvolps22
06-05-2006 10:48 PM
Quick Reply: Engine lose power when heated
