Front End Floating
Old 09-25-2007, 01:15 PM
cingulus's Avatar
Default Front End Floating
Hi Folks,
I bought a 2006 A3 last month. I love the car, but I have one issue. On the freeway the front end seems to float around. This is very odd since it handles in corners very well.
Has anyone else had this problem?
Was it something covered under warranty?
How did you fix it? (I assume new suspension, but I wanted to verifiy)[/ol]
Thanks,
Shaun
Old 09-25-2007, 01:18 PM
Default RE: Front End Floating
2006 will be under warranty so back to the dealers with it
Old 09-25-2007, 07:31 PM
Chef's Avatar
My "stock" A3 started floating around 145-150mph, so unless you're near those numbers, you might want the dealer to check it out.
Cheers!
Old 09-26-2007, 12:53 AM
lavadrifter's Avatar
Sounds like you might have a problem if it's real bad. The stock suspension definitely floats a bit at high speed. Combine that with the high "boost" setting on the power steering and you might as well be towing a skier. Better suspension did the trick for me. The car tracks much better now. You could always set the steering boost to 0 via VAG-COM if you want it real stiff.
Jbar
08-31-2010 11:02 AM
brrman
04-16-2009 04:26 PM
ne2q 73
01-19-2008 02:37 PM
whoismike
01-01-2008 09:20 PM
projlightning
11-12-2007 01:21 PM
Quick Reply: Front End Floating
