HELP - Carkit install - Audi A3 2005
Old 08-22-2008, 07:29 AM
francob's Avatar
Default HELP - Carkit install - Audi A3 2005
Hello all, I am nearly there with my Nokia CK-300 Handsfree kit installation to my Audi A3 2005 Concert Radio, except for the fact that it doesn't work. I beleive my cabling is not 100% right. I have attached pictures below to indicate the parts used and what is connected to what.
Carkit parts:
http://www.doubleclick.ie/WWW/iMAGE_00105.JPG
Car Radio:
http://www.doubleclick.ie/WWW/iMAGE_00104.JPG
Removing Radio:
http://www.doubleclick.ie/WWW/iMAGE_00106.JPG
Original cabling at the back of the Radio:
http://www.doubleclick.ie/WWW/iMAGE_00109.JPG
http://www.doubleclick.ie/WWW/iMAGE_00110.JPG
Cables from the back of the radio connected into the CA-139 cable :
http://www.doubleclick.ie/WWW/iMAGE_00114.JPG
The cables from the other end of the CA-139 cable into the Radio:
http://www.doubleclick.ie/WWW/iMAGE_00115.JPG
http://www.doubleclick.ie/WWW/iMAGE_00117.JPG
HFU and the cables that are connected into it:
http://www.doubleclick.ie/WWW/iMAGE_00118.JPG
The input device CU-10 :
http://www.doubleclick.ie/WWW/iMAGE_00119.JPG
Please note there are no LEDs on the above device, when radio powered on or ignition on. It seems that the HFU is not getting any power or am i missing how to turn on the bluetooth on the device.
Anyone performed an install like this before? Any suggestions on the cabling?
I have since found out that my Audi Radio is not compatible with standard ISO format? Is this correct ? if so what format is it compatible with ?
It was also pointed out to me that I have no iginition cable running to the HFU. Where is the best place to run this cabkle from ?
Francob
Old 08-22-2008, 02:32 PM
jetfuel's Avatar
Default BT car kit install
francob,
did you look into the Parrot system? they make a good set up for Bluetooth and you can use your steering wheel controls for a hands free operation.
mafpolo
03-27-2009 10:04 AM
Moonf4
01-03-2009 07:21 PM
xxteggiexx
07-07-2006 01:33 AM
TGPorsche96
03-23-2005 02:17 PM
gutshot
02-05-2005 01:37 AM
Quick Reply: HELP - Carkit install - Audi A3 2005
