KW V2 rear sits too low.. HELP!
Hi Guys,
I would like to seek your kind advice on my situation.
I recently purchased 2nd hand set of KW V2 from a seller that used for 3 months on his VW Golf V and he mentioned that it can be used for Audi A3 but alas upon installation, the it was found not suitable as the rear sits too low even at max height adjustment. The reason for this is I realized that I was provided the wrong information abt the KW V2 used by the seller as after further research, the KW V2 model that is suitable for my Audi a3 is Kit #: 15210040 but the part that I was misled into purchasing is Kit # 15281031.
I am currently considering a few options and one of the options is to change the rear KW springs with a taller springs to make my rear vehicle height higher. May I enquire whether is it possible to change the rear springs to a taller KW rear springs to solve my problem? If it is possible may I enquire whether the taller springs is suitable with the rear KW dampers?
Thanks!
Thanks!
crazyquik22023
08-15-2011 11:15 PM
410ThirtyValve
05-11-2009 10:07 PM
