Need advice on valuing my car...
Hey there Audi Forums! I’m green to the forum world and need some advice. I bought a 2007 A3 S-line Quattro several years ago that has an incredible amount of work. I purchased the car with 9020 miles on it, and currently the odometer reads 11688. It’s been sitting in a garage for the last few years covered and hooked up to a battery tender. Estimates rate it between 415/420HP and most of the work was completed by HPA Motorsports in BC. I have copies of most of the invoices but don’t have receipts for everything done. There is over $75K between parts and labor in the information I do have. The interior was worked over, stereo included. Exterior has an Oettinger body kit. The wheels are IMSA, and they are a 2&9/16” SINGLE lug with a conversion/adapter kit. The wheel/adapter set up was over $20K alone, I was told by the manufacture (in Germany) it is one of a handful of sets in the US. I have listed the mods below and numbers are rounded to the nearest dollar. I’m simply trying to get a feel for market value. I have pictures and would appreciate any interest or help I can get. This really is a spectacular example of a very well built, and very FAST A3 that deserves a good home and someone who will appreciate it. Feel free to send questions, and I’ll try my best to help. Or you can call me, Tim, at 816-726-6833 and I can send the info. I have pics. Thanks again!!
AUDI A3 S-LING QUATTRO SINGLE TURBO 3.2V6
HGP R30 GARRETT BALL BEARING BASED HYBRID TURBO - $23610.00
-CUSTOM COMPRESSOR HOUSING W/INTEGRATED RECIRC. VALVE
-CUSTOM EXHAUST HOUSING W/INTEGRATED WASTE GATE
-CAST EXHAUST MANIFOLD
-SHORT RUNNER CAST INTAKE MANIFOLD
-2X FRONT MOUNTED COMP. INTERCOOLERS W/VELOCITY AIR SHROUDING
-STAINLESS STEEL EXHAUST MANIFOLD HEAT SHIELD
-FLOW OPTIMIZED CAST DOWN PIPE FEED
-70MM DOWN PIPE W/INTEGRATED FLEX JOINT
-CUSTOM WRAPPED SILICON PIPING W/STAINLESS STEEL CLAMPS
-HIGH FLOW FUEL INJECTORS
-HEAD SPACER PLATE TO LOWER COMPRESSION TO 8.5:1
-BRAIDED STAINLESS STEEL OIL FEED LINE
-OIL RETURN LINES
-WATER INLET AND RETURN LINES
-UPGRADED ECU
-HIGH FLOW FUEL PUMP
-HIGH FLOW CATS
-RACE GRADE CON ROD BEARINGS
DSG TRANSMISSION - $4556.00
-UPGRADED DSG CLUTCH SYSTEM
-ELECTRONIC DIFF CONTROL MODULE
-POLY/E TOP ENGINE BUSHING
WHEELS – $19,800.00
-WHEELS FROM IMSA LAMBORGHINI
-FRONT 19X9 $4900.00 EA.
-REAR 19X10 $5000.00 EA.
SUSPENSION – $2437.00
-KW VARIANT 3 COILOVER SUSPENSION W/ADJUSTABLE BUMP & REBOUND
BRAKES – $3623.00
-BREMBO 14” CROSS DRILLED 2 PC. FLOATING ROTORS W/4 PISTON CALIPERS
MISC. ENGINE PARTS
-HALDEX SPORT CONTROLLER, GEN II - $1069.00
-Mk5 DOG BONE MOTOR MOUNT - $189.00
FUEL SYSTEM
-FUEL RAIL - $200.00
-HIGH FLOW FUEL LINES - $20.00
-4.0 BAR PRESSURE REGULATOR - $75.00
-FT SERIES AUX. IN-LINE FUEL PUMP KIT (FT 450) - $275.00
-FUEL FILTER - $50.00
CUSTOM EXHAUST
-MATERIALS - $1700.00
CUSTOM STEREO
-M-25 LASER JAMMER - $400.00
-KENWOOD EXCELON DDX8019 DVD RECEIVER - $1050.00
-KENWOOD I-POD INTERFACE - $27.00
-KENWOOD KNAG510 HIDEAWAY NAVIGATION - $500.00
-MISC. ADAPTERS/CABLES - $53.00
-DOUBLE DIN KIT - $55.00
-BACK-UP CAMERA (HIDDEN IN REAR KEY LOCK) - $UNKNOWN
-KENWOOD LZ702IR HEADREST MONITORS (2) - $700.00
EXTERIOR
-OETTINGER BODY KIT #532999 - $5500.00
PARTS/MATERIALS TOTAL - $65882.00
LABOR - $9561.00
FLUIDS - $231.00
TOTAL - $75,674.00
-OIL RETURN LINES
-UPGRADED ECU
-HIGH FLOW CATS
WHEELS – $19,800.00
BRAKES – $3623.00
MISC. ENGINE PARTS
FUEL SYSTEM
CUSTOM EXHAUST
CUSTOM STEREO
EXTERIOR
LABOR - $9561.00
FLUIDS - $231.00
TOTAL - $75,674.00
Good luck finding a home for this pretty lady!
Word on the street is that you never get the money back out that you put into a car so don't expect to get anywhere close to the total you listed (just my 2 cents).
BTW: Who the heck pays 20k for wheels?
The first owner was a Dr. in Atlanta GA and his brother in law worked at a Lambo dealer there. That's how he acquired the wheels from my understanding. The receipt shows $12,655 for wheels, but I called about replacement and the manufacture (in Germany no less) quoted $4900 for the front (19x9) and $5000 for the rear (19x10). Dunno how much the adapter kit runs...
