Need advice on valuing my car...
Old 11-23-2014, 01:15 AM
HUMMERguy's Avatar
Default Need advice on valuing my car...
Hey there Audi Forums! I’m green to the forum world and need some advice. I bought a 2007 A3 S-line Quattro several years ago that has an incredible amount of work. I purchased the car with 9020 miles on it, and currently the odometer reads 11688. It’s been sitting in a garage for the last few years covered and hooked up to a battery tender. Estimates rate it between 415/420HP and most of the work was completed by HPA Motorsports in BC. I have copies of most of the invoices but don’t have receipts for everything done. There is over $75K between parts and labor in the information I do have. The interior was worked over, stereo included. Exterior has an Oettinger body kit. The wheels are IMSA, and they are a 2&9/16” SINGLE lug with a conversion/adapter kit. The wheel/adapter set up was over $20K alone, I was told by the manufacture (in Germany) it is one of a handful of sets in the US. I have listed the mods below and numbers are rounded to the nearest dollar. I’m simply trying to get a feel for market value. I have pictures and would appreciate any interest or help I can get. This really is a spectacular example of a very well built, and very FAST A3 that deserves a good home and someone who will appreciate it. Feel free to send questions, and I’ll try my best to help. Or you can call me, Tim, at 816-726-6833 and I can send the info. I have pics. Thanks again!!
AUDI A3 S-LING QUATTRO SINGLE TURBO 3.2V6
HGP R30 GARRETT BALL BEARING BASED HYBRID TURBO - $23610.00
-CUSTOM COMPRESSOR HOUSING W/INTEGRATED RECIRC. VALVE
-CUSTOM EXHAUST HOUSING W/INTEGRATED WASTE GATE
-CAST EXHAUST MANIFOLD
-SHORT RUNNER CAST INTAKE MANIFOLD
-2X FRONT MOUNTED COMP. INTERCOOLERS W/VELOCITY AIR SHROUDING
-STAINLESS STEEL EXHAUST MANIFOLD HEAT SHIELD
-FLOW OPTIMIZED CAST DOWN PIPE FEED
-70MM DOWN PIPE W/INTEGRATED FLEX JOINT
-CUSTOM WRAPPED SILICON PIPING W/STAINLESS STEEL CLAMPS
-HIGH FLOW FUEL INJECTORS
-HEAD SPACER PLATE TO LOWER COMPRESSION TO 8.5:1
-BRAIDED STAINLESS STEEL OIL FEED LINE
-OIL RETURN LINES
-WATER INLET AND RETURN LINES
-UPGRADED ECU
-HIGH FLOW FUEL PUMP
-HIGH FLOW CATS
-RACE GRADE CON ROD BEARINGS
DSG TRANSMISSION - $4556.00
-UPGRADED DSG CLUTCH SYSTEM
-ELECTRONIC DIFF CONTROL MODULE
-POLY/E TOP ENGINE BUSHING
WHEELS – $19,800.00
-WHEELS FROM IMSA LAMBORGHINI
-FRONT 19X9 $4900.00 EA.
-REAR 19X10 $5000.00 EA.
SUSPENSION – $2437.00
-KW VARIANT 3 COILOVER SUSPENSION W/ADJUSTABLE BUMP & REBOUND
BRAKES – $3623.00
-BREMBO 14” CROSS DRILLED 2 PC. FLOATING ROTORS W/4 PISTON CALIPERS
MISC. ENGINE PARTS
-HALDEX SPORT CONTROLLER, GEN II - $1069.00
-Mk5 DOG BONE MOTOR MOUNT - $189.00
FUEL SYSTEM
-FUEL RAIL - $200.00
-HIGH FLOW FUEL LINES - $20.00
-4.0 BAR PRESSURE REGULATOR - $75.00
-FT SERIES AUX. IN-LINE FUEL PUMP KIT (FT 450) - $275.00
-FUEL FILTER - $50.00
CUSTOM EXHAUST
-MATERIALS - $1700.00
CUSTOM STEREO
-M-25 LASER JAMMER - $400.00
-KENWOOD EXCELON DDX8019 DVD RECEIVER - $1050.00
-KENWOOD I-POD INTERFACE - $27.00
-KENWOOD KNAG510 HIDEAWAY NAVIGATION - $500.00
-MISC. ADAPTERS/CABLES - $53.00
-DOUBLE DIN KIT - $55.00
-BACK-UP CAMERA (HIDDEN IN REAR KEY LOCK) - $UNKNOWN
-KENWOOD LZ702IR HEADREST MONITORS (2) - $700.00
EXTERIOR
-OETTINGER BODY KIT #532999 - $5500.00
PARTS/MATERIALS TOTAL - $65882.00
LABOR - $9561.00
FLUIDS - $231.00
TOTAL - $75,674.00
Old 11-23-2014, 06:37 PM
sheldon's Avatar
Good luck finding a home for this pretty lady!
Word on the street is that you never get the money back out that you put into a car so don't expect to get anywhere close to the total you listed (just my 2 cents).
BTW: Who the heck pays 20k for wheels?
Old 11-24-2014, 03:54 AM
rAtey's Avatar
Not got the money or the knowledge.... but.. . .. please show us some pics!
Old 11-24-2014, 12:38 PM
HUMMERguy's Avatar
Default Hope these turn out...
OK, still trying to figure out the Forum thing (not ever really participated in them and not sure how all this stuff works)So here goes...only allowed 5 pics, but here's one of my babies...
Old 11-24-2014, 12:45 PM
HUMMERguy's Avatar
The first owner was a Dr. in Atlanta GA and his brother in law worked at a Lambo dealer there. That's how he acquired the wheels from my understanding. The receipt shows $12,655 for wheels, but I called about replacement and the manufacture (in Germany no less) quoted $4900 for the front (19x9) and $5000 for the rear (19x10). Dunno how much the adapter kit runs...
Old 11-24-2014, 12:48 PM
HUMMERguy's Avatar
The first owner was a Dr. in Atlanta GA and his brother in law worked at a Lambo dealer there. That's how he acquired the wheels from my understanding. The receipt shows $12,655 for wheels, but I called about replacement and the manufacture (in Germany no less) quoted $4900 for the front (19x9) and $5000 for the rear (19x10). Dunno how much the adapter kit runs... Not very clear pics here but if you google IMSA Lamborghini you'll probably see a set on a few...
Old 11-24-2014, 03:50 PM
sheldon's Avatar
Thanks for the update with Pictures. Looks really good and clean. I still don't see how someone could spend this much money on wheels.
Love the car - but way out of my price range
Old 11-24-2014, 06:41 PM
HUMMERguy's Avatar
Not so much looking to get what's in the car, just trying to see what it's worth given the condition, mileage and work done to it. Thanks for the response though...
gshultz75
04-26-2013 01:22 PM
Mklee53
06-07-2008 10:31 PM
freezeskier332
06-05-2008 01:02 PM
jkettle
05-27-2008 08:25 PM
luke30
09-27-2006 01:59 PM
Quick Reply: Need advice on valuing my car...
