PCV Valve replacement help
Old 04-23-2011, 09:40 AM
cargovoyage's Avatar
Default PCV Valve replacement help
Hello- I have a 2008 Audi A3 which I recently had chipped. (best decision ever) The car has 65k on the motor and I'm trying to be proactive and replace some parts (fuel filters, O2 sensors, PCV valve) I am very confused as to which PCV or Pressure Regulator Valve I need to order. Can anyone help with a model number or link?
Also, does anyone know if I should go ahead and replace the O2 sensors or wait?
Thanks
Old 04-25-2011, 02:34 PM
Jeff-AudiUSAParts's Avatar
Former Sponsor
Hello, I'd like to help answer some of your questions. The pcv valve doesn't look like your older traditional type. Our techs call this a labyrinth, it bolts to the valve cover and does the same job as the traditional pcv valve. They plug up quite a bit though. It is 59.63 for the 4 cylinder one I think it is. The fuel filter is 51.00 and appears to be in with the in-tank fuel pump. A new fuel pump would come with the filter from what my picture tells me. I'd need your vin# to double check for the correct parts.
I asked a tech, he said the 02 sensors are replaced when they fail. He didn't state any mileage interval for replacement on a maintenance schedule.
I hope this helps, please let me know if you have any questions. Thanks, Jeff.
jlshelton
07-05-2011 11:04 AM
Deekster22
01-31-2010 10:07 PM
ncsume
11-16-2009 10:04 AM
jblum
02-22-2005 12:35 AM
Narcissus
01-22-2005 02:41 AM
Quick Reply: PCV Valve replacement help
