Reset Service Reminder
Old 05-30-2008, 07:36 PM
Barn's Avatar
Default Reset Service Reminder
I have a 2006 A3 and I can't figure out how to reset the service reminder after I changed the oil. I have done lots of searches and tried a few things but everything I've read seems to be for older audi's .... can anyone help?
Old 05-31-2008, 01:31 AM
4RINGSROD's Avatar
Default RE: Reset Service Reminder
Not sure but I think its a pattern with the trip reset stock. Check in the DIY section. or it may be here - AudiDIY (Do It Yourself)
Old 05-31-2008, 04:27 AM
hesaputz's Avatar
Or you could just admit that you're not a real man, and look it up in the owner's manual.
Old 05-31-2008, 11:27 AM
Barn's Avatar
ORIGINAL: hesaputz
It's not in the owners manual. I went through it several times. All it says is that the dealer will reset it when you get your oil changed
Old 05-31-2008, 12:39 PM
hesaputz's Avatar
Turn ignition on
pull out on the right hand instrument cluster **** - display should say SERVICE.
pull again to get SERVICE in XX Miles/Days
tap the reset buttom (bottom of right stalk) within 5 seconds to reset.
This is page 32 and page 47 of the '07 manual.
Old 06-05-2008, 07:57 PM
Barn's Avatar
Ya I tried that reset sequence in the manual but it doesn't work.
Any other ideas?
Old 06-06-2008, 12:57 AM
hesaputz's Avatar
I remember now that the book is a bit misleading. Get the service reminder up in the window, then pull and hold the button as you hit the reset. works fine, I just reset mine.
Old 06-06-2008, 12:19 PM
converted's Avatar
ORIGINAL: hesaputz
Or just pull once to get the reminder up and then pull and hold within 5 seconds and it will reset without pushing anything else.
Old 01-22-2015, 05:48 PM
rjkurtz's Avatar
Default 2012 A3 oil indicator light reset
I tried getting the service due up on the display and push reset button within 5 seconds. Did not work. Called Audi service and they said that $34.95 they can reset with a tool.
Any ideas?
Old 01-23-2015, 01:41 PM
sheldon's Avatar
Have someone with VAG-COM reset it for your or buy one. If you frequently work on the car you will end up needing one anyway
Quick Reply: Reset Service Reminder
