Timing belt A3
Old 08-30-2010, 02:40 PM
Joe albertino's Avatar
Default Timing belt A3
What,s every ones opinion on what mileage to change timing belt 2006 A3 Audi 2.0 liter.
Old 09-08-2010, 11:49 AM
dfrost's Avatar
The factory recommendation for timing belt replacement is 105,000 miles, but that seems long to me.
OTOH, I just had my intake camshaft replaced (along with the fuel pump and follower) at 71K. The mechanic looked at the timing belt and thought it looked fine.
I plan on replacing it around 85-90K.
Old 09-17-2010, 06:49 PM
dillo1's Avatar
Def change timing belt before 105,000 mls. I would recommend changine at 60-70,000 miles. Also change all tensioners and water pump. Full kit includes belt, tensioners, water pump etc. The price of change is mainly down to labour so when the engine is taken apart to change belt you might aswell change pump also.
Old 09-22-2010, 03:55 PM
LTA3's Avatar
Default Rubbing sound is not your belt!!
The rubbing sound at 1500rpm is not your timing belt... Your steering fluid is low. Refill the fluid and the sound will magically dissapear!!
Audiguruforyou
09-20-2011 01:31 AM
vtraudt
04-01-2011 09:40 AM
TheBat
06-20-2008 01:14 PM
Quick Reply: Timing belt A3
