1997 audi A4 1.8 T transmission problem
I rebuilt the engine of my a4 ,now that I put it back the car barely move like if the transmission have no olil pressure; I'd check the oil level and is ok, vag com say there is a fault on the multifuncional switch' .
If you put the car on drive and push the gas the car just don't go,neither in reverse,and after put the shifter back in neutral all the lights PRD234 will come on the dashboard, I'm very frustrated especialy becouse I put near $ 3000 on this long block and now the car doesn't move; if someone have any idea ,please letme know.Thanks
RE: 1997 audi A4 1.8 T transmission problem
i believe when all those lights come on ur in limp mode. couldn't tell u bout anything else though. pm auditech79, cincytt and techbod. they should be able to help u
Did you have the trans out? Maybe you just left something unplugged/unconnected. Was the torque converter fully seated? If not you may have damaged the trans pump during engine installation.
Sometimes they can stick to the engine during removal and come out just a little bit. Did you have any trouble getting the trans and engine to meet up flush with eachother when you put the engine in?
