Sponsored by:
Sponsored by:
2001 A4 Brake lights
Old 07-30-2013, 12:44 PM
nick_osi_a4's Avatar
Default 2001 A4 Brake lights
Hi all;
I just recently bought a 2001 A4 1.8T Quattro and it seems to have a ton of problems, mostly electrical. the first problem I want to tackle is the brake lights, they seems to be on as soon as I start the car, and they only get a very slight bit brighter when I press the brakes. This includes the high back light in the rear window. The warning light about the brake light failure is on (complete with annoying beep) and the cruise doesn't work either, which may be related. I have seen a lot of different posts on this forum about brake lights but none seem to be of ones with the lights on whenever the car is running and only get slightly brighter when the pedal is pressed. Is it possible this is from the pedal switch? I've seen this kind of problem before with RV's with bad grounds. I tried to have a look at the switch but the panel under the dash seems to be a challenge to remove, any trick to that?
Thanks in advance for all the help.
Old 07-30-2013, 08:15 PM
Ok, so I got that problem figured out, it was just one bulb in the brake lights, someone had put in a single filament when it should've had a dual filament, i hand't checked it yet because it seemed to be working. the next problem I have is the power windows don't work, some have said something about a central comfort module. Any help on that??
Thanks!
dunanga
10-15-2011 04:53 AM
hpz
04-05-2010 01:48 PM
pezster
10-30-2008 11:37 PM
cbing28
03-19-2006 01:33 PM
Quick Reply: 2001 A4 Brake lights
