New to Audis & Forum
RE: New to Audis & Forum
you should have your belt changed or about to change, the pumps checked, there are othert things you should worry about like changing oil, and stuff, but i guess you should kno that you should give your car a resting period when u run it hard by lettin it iidle for a min. theres are other things im sure the other B5ers in this forum will let u kno
you could probably remove the plastic timing belt covers and check for timing belt wear. If it hasnt been changed in 81k miles the belt should have little cracks and the writing should be faded.
