Sponsored by:
Sponsored by:
2014 A4 2.0 Check Engine Light
Old 04-21-2016, 05:34 PM
abelga4's Avatar
Default 2014 A4 2.0 Check Engine Light
Check engine light came one. I'm past the 50,000 mile warranty (I am at 54,000). Audi service department gave me codes: P227900 Intake Air System Leak and P218700 System too lean at idle, Bank 1.
I opened hood and noticed a leak noise coming from picture attached. Does anyone know what part this is? Or why it is leaking? Thanks in advance.
File Type: pdf
Old 04-25-2016, 10:20 AM
rhodes991's Avatar
That is the PCV. They can go bad. About an $80 part and easy to change out.
https://www.ecstuning.com/Audi-B8_A4....0T/ES2707347/
Product Details
From the 2013 model year
The PCV provides a one way exit for gasses built up in the crankcase. Over time, contamination might cause reduced air flow and cracks can occur in the housing. If your car is experiencing a loss of boost pressure or a decrease in performance with a rough idle, this valve might to be blame. This valve sits on the cylinder head valve cover.
INDUSE
B8 Models
12-18-2014 07:19 PM
Andrew/AWE
08-06-2014 05:28 PM
juliet5108
05-05-2014 11:02 AM
rockhoward
04-28-2014 12:38 PM
blanthony
03-25-2006 01:18 PM
Quick Reply: 2014 A4 2.0 Check Engine Light
