A4 Radio Antenna
A4 Radio Antenna
My radio never worked, I finally want to fix it but I can't locate the antenna wire, that I suspect to be the reason why my BOSE radio does not work. The CD works fine, fuse is ok....You guys have any idea how to reach the antenna?
Thank you
Thank you
RE: A4 Radio Antenna
Nope, Have to buy those tools to remove the radio, I looked around the ampli in the left side of the trunk, I didn't had much time today, I was looking for informations before starting to look around.
Thanks for the reply.
I'm assuming you mean the horrible reception the Bose radios get. I've got the same one, and there isn't much you can do. AM is the worst. I even tried an antenna booster when I was in Michigan. Bad idea, it created a wicked ground loop problem and I couldn't take the hum. If you do get the keys to take the radio out, it takes about 4 seconds to do. Make sure youou have your radio code before you disconnect the power from the radio. The dealers now charge you 35 buck to get the code for you. I've decided to get Sirius because I'm tired of driving in and out of reception all day.
Well it picks up ONE station, I believe the antenna is broken or disconnected...I have "hissing" static noises on any other frequence.
ORIGINAL: Doose
Great, I'll start checking the rear window removing the rear panel where the speakers are. When I bought the car the WW dealer ( selling also used AUDIs ) could not figure out where th e problem was, and they removed all the panels covering the line from the BOSE in front to the rear seats. I assume that the problem could be closer to the rear window then.
ORIGINAL: Jestnomen
Well the antenna is built into the rear window. There is also a antenna amplifier close to the window. There should be a harness that goes from the window up to the radio of course.
i have bad reception too. I have replaced the radio with an aftermarket but it didn't get any better, but i dont really care cause i just listen to my ipod sice i got that new alpine thing.
