Sponsored by:
Sponsored by:
VAG and Coil Packs and VW vs Audi
Old 09-13-2006, 02:17 PM
Sydeshow MO's Avatar
Default VAG and Coil Packs and VW vs Audi
Will the VAG-Com tell you if you have a bad coil pack or will it just show a code for misfire?
Also is there a difference in VW vs Audi coil packs?
06C905115H - Audi Part#
06C905115L - VW Part#
Thanks
Old 09-13-2006, 05:08 PM
acetrebo's Avatar
Default RE: VAG and Coil Packs and VW vs Audi
Since VW makes audi, none. Probably have the same engine.
Vag-com will just give code for the misfire. You need to trouble shoot to find out if its bad.
Easiest way is to find out which cylinder is misfiring with a code reader or vagcom.
Then, swap the coil pack with another cylinder, and see if it follows the coil pack or not.
xxNeverG1veUpxx
12-04-2013 05:50 PM
drft1
07-05-2010 12:19 PM
bholmes
04-03-2007 01:25 PM
Sydeshow MO
09-13-2006 02:09 PM
Quick Reply: VAG and Coil Packs and VW vs Audi
