Audi A4 Tdi 1.9 Breather blocked? - AudiForums.com
Reply
LinkBack Thread Tools Search this Thread
Old 02-24-2009, 06:11 AM
Default Audi A4 Tdi 1.9 Breather blocked?
Hi all,
I have recently developed a strange problem with my Audi A4, when accelerating up hill I noticed that the performance had decreased slightly, then when I came to a stop I could smell a burning inside the car and could see a couple of wisps of white smoke coming from under the bonnet. All the temp gauges were fine. I got home and gave it a full oil change (using engine flush etc) and changed the oil filter, but I still seem to have this issue. I can still feel the turbo kick on on straights, however I have problems accelerating past 50 on slight upward gradients. The only other thing I have noticed is that there is a ball shaped section with a slightly elongated hole which appears to be part of the turbo that has spat out black soot over the engine (see photo).
I presume that the breather may be blocked... however I have read that some have had sludge in the manifold or and friends have suggested that the the turbo may be on its way out? Before I take it into the garage I was wondering if anyone could tell me what they think that the problem is? Any help you could give would be much appreciated, as I would rather go prepared to the garage.
Old 02-24-2009, 03:13 PM
Default Have visited a Diesel Engine Repair Shop
Hi again,
I visited a diesel engine expert on the advice of a friend, just for a quick overview. He informed me that he believes that the cat is blocked and that I more than likely need a new one. I have had a quote for 150 for a replacement and fitting. I tried to get the old one off to see if I could clean it out, however the bolts are pretty stuck and their angle means that its difficult to get the leverage so I was worried I might round them off.
Though I can't see a 100% way to check whether this is the problem, I will double check with the garage that is fitting the cat to see whether they also think this is the problem. Again if anyone thinks this sounds about right I would appreciate the advice.
If I manage to find out I will post for others.
Reply
Thread Thread Starter Forum Replies Last Post
Porsche would have entered F1 if Audi had blocked its Le Mans program Audi Forums Editor Brand News, Concepts & Rumors 0 03-13-2014 05:08 PM
Help installing breather hose,W0133-1624629 Breather Hose, on back on engine copper07 Audi A6 9 10-02-2012 05:07 PM
Audi Breather Hoses - Audi Crankcase Breather Hoses Kit vtraudt Audi A6 1 07-18-2012 02:11 PM
could a blocked oil passage..... patty36j B5 Models 20 02-08-2012 07:02 PM
Resolving Blocked DPF Warning light-Regenaration-Audi A4 Sarah Mansoor New Member Welcome Area 0 01-11-2012 02:44 PM
Tags
a4, acceleration, audi, black, blockage, blocked, breather, check, clogged, hills, problems, smoke, tdi, uphill, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
