Sponsored by:
Sponsored by:
Car heater not working - blowing cold
Old 10-21-2010, 10:43 AM
brightm's Avatar
Default Car heater not working - blowing cold
Hi,
Can anyone help. I had a problem with the temperature gauge not working on an Audi A4 1.8T 2002. I replaced the temperature sensor at the back of the engine but that didn't work so replaced the thermostat. Now the gauge works fine (dial points to 90) but the heater is blowing cold air. There is a leak from the pipe to the coolant flange (coolant flange has been replaced) but i'm toping that up until the pipe arives (o ring failure). When i first did the thermostat the heat was coming through fine but three days later I have just cold air. Is it likely to be an air lock? Thanks for any assistance!
Old 01-05-2015, 11:52 AM
asward22's Avatar
HELP!!!! 1998 Audi a4 changed radiator thermostat, bleed system air blows but not hot set on 80 degrees tried everything any ideas
PaulCunningham
B7 Models
10-17-2013 04:54 PM
dom_mewes
02-11-2013 05:23 PM
soltisb
01-24-2013 09:26 PM
skatehorse_01
10-28-2008 08:37 PM
gregp1962
12-17-2007 02:21 PM
Quick Reply: Car heater not working - blowing cold
