changing water pump on 2000 1.8t
gday, i need to change my water pump according to the shop. id rather do this myself.
can anyone give a me a step by step guide, ie how to losen the correct belts, and do i need to remove the front bumper?
any help would be appriciated.
also does anyone know what the part is worth?
RE: changing water pump on 2000 1.8t
This is a decent guide here for the water pump. I HIGHLY suggest you change the timing belt also when doing the water pump. Its something that should be done at 90k miles and can cause up to $3000 damage if breaks.
http://www.audiworld.com/tech/eng35.shtml
I got the kit for my A4 here that has both the timing belt, water pump and more here http://www.dieselgeek.com/
Good luck!
Good luck!
ORIGINAL: north5995
I'm doing mine this summer. How long did it take you? Any words of adivce?
