Sponsored by:
Sponsored by:
changing water pump on 2000 1.8t
Old 02-27-2006, 05:55 AM
millsi's Avatar
Default changing water pump on 2000 1.8t
gday, i need to change my water pump according to the shop. id rather do this myself.
can anyone give a me a step by step guide, ie how to losen the correct belts, and do i need to remove the front bumper?
any help would be appriciated.
also does anyone know what the part is worth?
Old 02-27-2006, 06:23 AM
Jovian's Avatar
Default RE: changing water pump on 2000 1.8t
This is a decent guide here for the water pump. I HIGHLY suggest you change the timing belt also when doing the water pump. Its something that should be done at 90k miles and can cause up to $3000 damage if breaks.
http://www.audiworld.com/tech/eng35.shtml
I got the kit for my A4 here that has both the timing belt, water pump and more here http://www.dieselgeek.com/
Good luck!
Old 02-27-2006, 11:16 AM
Jestnomen's Avatar
6th Gear
Actually most people on the forums recommend 60-70k miles for timing belt/water pump/tensioner change. I've seen lots of failures at these mileages.
Old 02-27-2006, 12:45 PM
70k for timing belt/tensioner/idler roller(s) but if changing the pump its common sense to do the others it will save money in the long run
Old 02-27-2006, 12:50 PM
Jestnomen's Avatar
6th Gear
Yep they should all be changed including the thermostat.
Old 02-27-2006, 12:56 PM
forgot that one lol also the coolant because you will lose it all when the pump is removed
Old 02-27-2006, 03:06 PM
mjvss21's Avatar
i jsut used that write up this weekend and it worked great.
Old 02-27-2006, 03:10 PM
north5995's Avatar
I'm doing mine this summer. How long did it take you? Any words of adivce?
Old 02-27-2006, 03:13 PM
no words of advice im a mechanic so its easy for me, just take your time and read the books
onepoint8tee's Avatar
ORIGINAL: north5995
Takes about5-8 hours for the tbelt and everything else mentioned above depending on your skill.. My advice would be to not **** it up.
Quick Reply: changing water pump on 2000 1.8t
