Sponsored by:
Sponsored by:
clutch replacement instructions plz
Old 10-30-2007, 11:39 PM
lewissmith's Avatar
Default clutch replacement instructions plz
to begin withi have a 2001 s4 no mods, i allready posted in the s car forum and no one there likes to respond back so i was hoping someone here would plz help me,my clutch went out and im replacing it with an rs4 clutch, i need instructions on how to replacemy old clutch and some tourque specs... i appreciate any help, thanks in advance
Old 10-30-2007, 11:51 PM
chaos92287's Avatar
Default RE: clutch replacement instructions plz
i dont know of any online. you could buy a bentley manual
Old 10-31-2007, 12:10 AM
lewissmith's Avatar
i cant afford it right now
Old 10-31-2007, 12:48 AM
chaos92287's Avatar
oh well if you can't find an answer here, try audiworld.
FASTER's Avatar
Tech Slut
are you mech savy at all cuz this is no easy job for a beginner. im sure someone has a detailed diagram of how to do it but i wouldnt jump into it unless you know you can do it.
Old 10-31-2007, 01:11 AM
pyropenguin's Avatar
www.audidiy.com
Old 10-31-2007, 03:39 AM
khj677turbo's Avatar
Thought bentley manual was like 20 bucks?? U want to do your own work, save money i presume but wont do a little investing, im sure if you invest in a 20 dollar book youll still net some profit
Old 10-31-2007, 07:07 AM
99A4NOW's Avatar
A Bentley shop manual for $20, please someone tell me where I can get that! A Haynes manual maybe, but I don't know if they have one for the S4.
Still, a true Bentley manual is only about $70 I think. So you want to spend extra cash on an RS4 Clutch but cant for-go the small amount for a proper manual to do the job right? I don't think you should be attempting this yourself. A job of this magnitude shouldn't be guided by a tech article on the Internet IMO.
But if you must, Start by removing everything in the way of getting to the top bolts of the tranny bell housing, then put the car in the air on a lift. Remove the exhaust downpipes, support the tranny with a tranny jack, unbolt the driveshafts, transmission mounts, and unbolt the lower bolts for the tranny. Remove the hydraulic clutch cylinder and remove the tranny. Remove clutch and flywheel (you are replacing the flywheel too, right?). Replace all bolts with new ones and reinstall the new clutch. Reassemble is the reverse of disassembly.
tpaudi
10-06-2011 12:33 AM
lewissmith
11-04-2007 10:48 PM
rguinto
06-11-2006 01:00 PM
jpr11530
12-05-2005 11:47 PM
kchao2000
04-11-2005 08:34 PM
Quick Reply: clutch replacement instructions plz
