CONNECTING LINK (SWAY BAR LINK)
you know the thing that looks like a C clamp. that connects the sway bar.
the question is, should there be any play?
i noticed that my front end started to have some play...
i did not know if i broke somthing or busted a strut..
i have intrex lowering springs, with kyb struts..now i know kyb is not the best, and from what i understand, if i had the springs put in with stock struts, i may bust them...
so i looked at everything and the only thing i could find out of place
was the connecting link on the pass side had alot of play, almost none on the driver side.....
i tried it with the car up and on the ground....the result the same..
what do you think (beside i need better struts)?
thanks in advance
E
thanks in advance
E
