esp light has come on - AudiForums.com
Reply
LinkBack Thread Tools Search this Thread
Old 06-30-2005, 08:16 PM
Default esp light has come on
The esp light has come on and stayed on in my '02 1.9 tdi Sport. Pressing the esp button does nothing. Are there any known/common failures in the esp system that are worth checking before taking it to the agent? I get the feeling this could be expensive...
Old 06-30-2005, 09:41 PM
Default RE: esp light has come on
The ESP has its own fuse - check if its blown for any reason. Short in the system?
Other than that - I cant suggest anything else.
Old 06-30-2005, 09:51 PM
Thanks. I'll check that out tomorrow and report back
Old 06-30-2005, 09:53 PM
Oh and one other thing. Since the esp warning has come on, the ABS light sometimes comes on and sometimes doesn't. haven't done the 'slam the anchors on hard and see if it pulsates' test yet but will do tomorrow
Old 06-30-2005, 10:06 PM
I have both ESP and ABS on. I'll check fuses. Thanks.
Old 06-30-2005, 11:13 PM
rs rs is offline
mite be a leak somewhere in ur hoses, when the dealer was attaching my front bumper, they dmg one of the hoses, and my car was jerking like carzy when i got home, esp and abs light were both on, and the car was just rattled, not sure if its ur exact problem, but somethin to look into
Old 06-30-2005, 11:36 PM
Not my problem, I'll try to find someone with a VAG-COM.
Reply
Thread Thread Starter Forum Replies Last Post
left rear running light does not work nor the gauge cluster light at the same time? mannyg_87 Electronics 0 02-23-2015 04:08 PM
01 a6 quattro 2.7T Tail light, fog light, and side marker light question. crazybk187 Exterior 0 08-05-2013 05:29 PM
B5 Audi a4 High mount brake light (third bake light), light replacement??? Pbcrazy B5 Models 7 09-07-2012 05:25 PM
Check Engine Light, ESP Light, And EPC Light MULEPERFORMANCE B6 Models 4 02-23-2010 07:31 PM
Check Engine Light & ABS Light and Flashing Brake Light blanthony Audi A6 1 03-25-2006 02:18 PM
Tags
08, 18t, 2005, 25i, a4, abs, audi, eps, esp, forums, impreza, jerking, light, reset, subaru
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
