fault code
fault code
hey everyone i got a fault code
01274 it said something about the motor flow and blocked with no voltage.
i also got the code 00849 i was wondering how could i fix the motor flow problem? and what should i do about the 00849 code. thanks.
RE: fault code
Are you sure that you wrote the codes down correctly? I can't find them in my book.
If you are friendly with the person with the vag, have them pull the codes and download them to a file so you can upload them here along with the other information that comes off a vag, such as what system it is from. etc.
RE: fault code
i looked on audiworld it said 00849 - S-contact at Ignition/Starter Switch -D- But why would this code come up?
and the other one is
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
