question about light
I have a 2003 audi a4. On my LED display, there is a warning light (similar to where the gas warning shows up) that has a circle and then another circle in the form of a dotted line around the inner circle. It looks like a tire to me, so I'm thinking that the tire pressure is low, but I just wanted to check with the experts here first, since I don't have an owner's manual . If it is indeed the tires being low, how much should I fill them?
Thanks so much!
-Thomas
Thanks so much!
-Thomas
RE: question about light
Yea, that is for the front brake pads...There is a sensor in the pad and when it gets low it breaks, similar to when you hear brakes squeaking you get to the wear bar....Same thing, but there's a sensor instead of a wear bar
Thanks so much for the responses! This is very helpful. I went out and bought some brake fluid, and found the compartment in the car in which it goes. I took the first cap off and started pouring (into a filter-like thing). However, it didn't really go in, it just kind of spilled, so I stopped pouring. Is there a special way to put it in? Thanks.
Also, do I just need to add brake fluid, or do I need to take the old fluid out? Thanks!
Ok, the story develops a bit more. I showed it to a mechanic-type who knows what he's doing and he said the brake fluid was full. However, the brake pads are pretty new (~6 months), so I don't think it is that. More recently, the brake light started flickering (as well as the light I mentioned up above). Any ideas what could be going on? If not, I'll probably just take it to the mechanic.
Thanks!
Thanks!
crazybk187
08-05-2013 04:29 PM
