Fault Code -- P0024
Fault Code -- P0024
My check engine light came on and I did a dignostic test and the result was the following fault code
Code Definition
P0024 -- "B" Camshaft Position - Timing over-advanced or system performance.(Bank 2)
I just bought my A4 about a month and a half ago it has 61,000 miles on it. I am concerned this could be something real serious. Does anyone have any helpful information on this subject???
Code Definition
RE: Fault Code -- P0024
It is a 2002 and I did try to reset it and it came back on. It has been running okay. When I look up the code at the following website it says 16408 - advanced timing http://www.gerritspeek.nl/vag-com_fo...-en.html#autos
Im not finding the code where I usually look, at the Bently website.
Here's the list from there.....
16394
P0010
-A- Camshaft Pos. Actuator Circ. Bank 1 Malfunction
16395
P0020
-A- Camshaft Pos. Actuator Circ. Bank 2 Malfunction
16449
P0065
Air Assisted Injector Control Range/Performance
16450
P0066
Air Assisted Injector Control Low Input/Short to ground
looks similar to P0020. But according to bently, its not an audi fault code.
Anyway, it looks like either the cams are not lined up with each other, or your camshaft position sensor on one side is shot, or your timing belt has become off and jumped a tooth or something.
Has the t-belt been changed on the car ever?
I would certainly have this looked at, maybe take it somewhere and get an estimate, they may know whats wrong and then you could fix it yourself.
16394
P0010
16395
P0020
16449
P0065
16450
P0066
Yeah if it's a timing belt issue that COULD turn serious. Audi engines are interference based engines so if your timing belt comes off or is off to much your cylinder heads will hit your valves and that will mess stuff up REAL quick! Then you get to replace a whole bunch of stuff and it's not cheap. Have that looked at ASAP!
Josh
Josh
The only time I have seen that fault is when the belt has jumped time or someone f*** up putting on the belt. I would check the timing and if its off replace the belt. If it is off and its more than 2-3 teeth you may have a bigger problem
