Sponsored by:
Sponsored by:
Front Fog Lights - A4 Cabriolet B7.
Old 01-02-2017, 04:31 PM
wolfboy's Avatar
Default Front Fog Lights - A4 Cabriolet B7.
Hi,
I recently started to get a warning message on starting the engine, " Front Fog Light not Working'. As it happens, neither front fog is working, so I though I would check the fuse (according to manual no. 19).
However, when checking the fuses there was no no. 19, also the slots aren't labelled so if there was one, it's difficult to see where it should be. What's going here, is the owners hand book wrong?
Also, should I need to replace the bulbs, can it be down without removing the front bumper?
Regards
Martin
Old 01-11-2017, 01:44 PM
rhodes991's Avatar
When I changed out my bulbs I pulled the front bumper (wasn't as bad as I thought it would be). I can say that as I had to pull it back off two weeks later has one of the new bulbs was failing. Okay, maybe I didn't seat the bulb fully! I want to say I could reach my driver's side fog with the bumper on, but not the passenger side. Could be wrong in that. They are much easier to change with the bumper off. I went ahead and changed all my bulbs (I had a head light out) while I had the bumper off.
Not sure about the fuse issue, but I would make sure it isn't that first.
lilman05
12-23-2017 01:26 PM
lilman05
09-20-2006 11:06 PM
lilman05
09-20-2006 10:19 PM
mikehh
02-05-2006 12:08 AM
pherder
12-09-2005 07:51 PM
Quick Reply: Front Fog Lights - A4 Cabriolet B7.
