Sponsored by:
Sponsored by:
Custom Downpipe
Old 04-23-2007, 01:01 PM
AudiTurbo's Avatar
Default Custom Downpipe
Ok well im trying to get some idea from people on how hard it is to make a custom downpipe. My flexpipe is blown out, and I want to just got ahead and replace it with a bigger downpipe. Can i make a 2.5 inch dp, and still run it on stock cat and exhaust? and if I get a bigger cat and exhaust will it still work. I just want to get a dp for now, because im going to trade for a s4 soon....How hard is it going to be, and what is a good price range?
Old 04-23-2007, 01:21 PM
SacTown_Vlad's Avatar
Default RE: Custom Downpipe
talk to your local exhaust shop for custom work… but I would get original part from junk yard, it would cost you less and u wont see much performance running on stock cat and exhaust.
Old 04-23-2007, 01:28 PM
AudiTurbo's Avatar
Yeah, but I was going to go ahead and make it bigger just in-case I keep the car...
Old 04-23-2007, 01:34 PM
A4speed's Avatar
techtonics.com has high flow cats and downpipes that are 2.5
Old 04-23-2007, 01:41 PM
AudiTurbo's Avatar
ORIGINAL: A4speed
Will the dowpipe fit a stock exhaust though?
Old 04-23-2007, 02:06 PM
Soley4pres's Avatar
yes it should .. it will need to be welded on ...the dp and high flow cat will bolt up nice gains and quicker turbo spool ..the dp may have to be welded on to your existing stock exhaust but a exhaust shop should do the install and it wouldnt cost very much
Old 04-23-2007, 03:38 PM
AudiTurbo's Avatar
ok thanks...should I even worry about the custom then, or just buy it and have it put on?
Old 04-23-2007, 03:56 PM
A4speed's Avatar
Well, I wouldn't worry about the custom job. Cat's use to be $6-700 for A4 until techtonics came out with theres for $295. So it's a way good deal.
Old 04-23-2007, 03:57 PM
A4speed's Avatar
your stock exhaust is 2, so you'd have to have a piece welded on from the downpipe to your normal piping.
Jchockey100
05-02-2012 11:34 AM
mattrazzo
02-20-2011 03:44 PM
FattieJayMack
06-18-2009 12:17 PM
deephouse
04-25-2008 04:40 PM
nvus1too
03-25-2007 02:39 AM
Quick Reply: Custom Downpipe
