Grinding noise
Grinding noise
i was driving in the snow the other day, and when i went to brake there was a nasty grinding noise (a lot like grinding gears). it only happened when i would brake hard. if i slowed down slowly, it didn't happen. it also happened on wet leaves when only one of my wheels was on them as i was parking. I'm assuming that the wheels are locking up. is this a problem with the ABS system? or does anyone know what it could be? all comments are appreciated, thanks.
RE: Grinding noise
the pads look fine, with plenty of life left in them, and the rotors look fine too...is there anything specific i should look for to tell if either the pads or rotors are bad? also...i dont know how to be more specific about the noise other than it sounds like gears grinding, not like the sound that pads and rotors would make (from my experience at least). what would grind if the wheels lock up?
