Sponsored by:
Sponsored by:
Hard Start
Old 12-01-2005, 08:11 AM
BadLuckAudi's Avatar
Default Hard Start
Hey, I have this problem with my car that every time I start it when its cold its really hard to start and if it does start right off it will sputter and die, but once its even semi warm after the first start it starts and runs perfectly fine, but then if I let if set for a little bit it will be hard to start again. It has done this ever since I wrecked it and I can’t figure out what is wrong it only sat upside down for less than an hour and nothing in the engine bay was touched. I don’t have a Vag but should be getting one soon (Christmas) is there any ideas on what it might be?? Also where is a good place to get a Vag com for the best price????
Old 12-01-2005, 09:43 AM
david9999's Avatar
Default RE: Hard Start
Vagcom has only one source, the manufacturer Ross Tech.
Could be bad coolant sensor. When is the last time you changed spark plugs?
Old 12-01-2005, 05:45 PM
Hmm i didnt change the plugs after the wreck i just cleaned them, my car only has 8,000 miles on it so i didnt think they would have gone bad yet, but i guess thats a good place to check. thanks
Old 12-01-2005, 05:46 PM
kingming's Avatar
ORDER THE CABLE ON E-BAY 35 SHIPPED... AND DL THE FREE SHAREWWARE FROM ROSS TECH I JUST HOOKED UP MINE TODAY
WORKS GOOD BUT NO ONE KNOWS MY AIRBAG CODE.....SEE MY POST IF YOU CAN HELP
Old 12-01-2005, 06:06 PM
clconversion's Avatar
sounds almost like a TBA problem do a throttle body alignment and see if it goes away
Old 12-01-2005, 07:52 PM
How do i do a throttle body alignment does it matter that its the NDBW one???
rccks96
08-29-2023 08:58 PM
ed1404
11-26-2011 06:31 PM
yknits18
04-15-2011 09:14 AM
sa9023
09-02-2010 06:31 PM
wings7351
06-06-2007 09:52 PM
Quick Reply: Hard Start
