Help fault code # p0171
Help me please My check engine light turned on today and i had the code ran at auto zone, and it came back with code p0171 (the fuel system for bank one was to lean) the employees there had no clue what that meant. so i went to checker auto and they ran the same code but it came back with fuel system to lean due to the MAF sensor what does this mean , how can i fix it, is it expensive......any help is greatly appreciated.....any one else have this problem with their audi, by the way i have a 2002 a4 Q auto. thank you all in advance..
RE: Help fault code # p0171
o mine are going out for a different reason then urs. there maybe a little bit of oil on the sensor. o ya MAF=Mass Air Flow sensor, it is located in the airbox there are wires going to the top of the airbox that then lead to the maf
ORIGINAL: cireecnop1
are they always going out? is there any way to maintenance them? by the way where are they or it?
No they aren't always going out. It's not abnormal for it to go out at 70k miles or so. You can try spraying the MAF element with a electronics tuner cleaner. I doubt it will do a whole lot though.
