Sponsored by:
Sponsored by:
Hood latch problem- cant open hood
Old 05-02-2007, 10:52 PM
pyropenguin's Avatar
Default Hood latch problem- cant open hood
I need your help.
So, a couple weekends ago i changed my timing belt. A couple days ago, I tried to open my hood, and I realized I forgot to connect my hood latch cable. So now, after trying to get help on the 'zine, and the local euro shop, I need serious help!
Here is the latch i need to release:
and here's a picture of the latch from my bentley-
Please help me!
Kyle
Old 05-02-2007, 11:06 PM
Bondga's Avatar
Default RE: Hood latch problem- cant open hood
i would suggest you try to slide your hand up the bottom and release it manually. then once it's open reattach it
Old 05-02-2007, 11:12 PM
Well I can't get anything up the backside, the radiator fans and the motor block it from underneath.
Old 05-02-2007, 11:13 PM
akoby9's Avatar
what about trying to stick something, mabye a screwdriving or coat hanger through the audi ring where the latch comes out usually? and then try to manually get it open
Old 05-02-2007, 11:17 PM
Bondga's Avatar
dosnt the front grill just pop off if you pull it(not sure) if thats the case maybe you can pull it off and get to it
Old 05-02-2007, 11:18 PM
I have the grill out right now, the problem is that there are two latches that need to be released, the first one (the circled one in the pic) releases by pulling to the side, and that one is behind the front clip, and down ~2", then the next one is easy, thats the one that sticks out of the grill.
A coat hanger may work... i'm starting to think i'll have to bend something to get it out.
Old 05-02-2007, 11:20 PM
Bondga's Avatar
can u unscrew the latch from the hood.
Old 05-02-2007, 11:24 PM
oh yeah! maybe, i'll go check that out now.
Can anyone get me a picture of the hood latch? I can see two bolts, but there has to be more. I just want to make sure before I start taking things off.
Old 05-03-2007, 12:44 AM
Bondga's Avatar
here ya go
[IMG]local://upfiles/22181/1C5B6D5CE34C44AF95BE761D60F9107B.jpg[/IMG]
[IMG]local://upfiles/22181/039B8B20DC7342F496FF178C8C23BC84.jpg[/IMG]
[IMG]local://upfiles/22181/D3E8FBB1C26C4F9AACC3598B04B53B63.jpg[/IMG]
Old 05-03-2007, 12:46 AM
Bondga's Avatar
looks like 3 bolts mines a 2000 so should be the same
Quick Reply: Hood latch problem- cant open hood
