AudiForums.com
Go Back   AudiForums.com > Audi Models > Audi A4
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read ExperienceGarageUsed CarsVendors TSBs
Search
Welcome to AudiForums.com
Sponsored by Audi Online Parts
Reply
LinkBack Thread Tools Search this Thread
Old 02-18-2005, 05:59 PM
Default How can I test a turn signal relay for function/failure?
Sorry if this question has already been posted, but I couldn't find the answer. My g/f's turn signals wont work, fuses are fine. Hazards still work. Bulbs are fine. At this point I assume it is the relay switch, but I have no idea wher it is located. I drive a [sm=hail.gif]1970 Dodge Dart Swinger. It is a Wright Flyer compared to the modern space shuttles you folks are driving. Any help would be appreciated. Thanx
Old 02-18-2005, 06:04 PM
6th Gear
Send a message via AIM to Jestnomen Send a message via Yahoo to Jestnomen
Default RE: Where is turn signal relay switch located?
turn signal relay is located inside the hazard button.
__________________
2005 A4 1.8tqm Avant
2004 VW Touareg
2005.5 Audi A4
Old 02-18-2005, 06:08 PM
Jestnomen,
Thanks. You own.
Subbie
Old 02-22-2005, 07:52 PM
Default How can I test turn signal relay function/failure?
Appearantly I didn't think far enough ahead. Is the hazard button attached to the actual relay? Do either of these seem consistant with an Audi relay switch part number: #8D0 941 509 H ? or
PA 6 GF30 ? Also, how can I check it to see if it is the culprit? I have a digital multi-meter.
Thanks,
Subbie
Old 03-04-2005, 01:46 AM
Jestnomen:
Glad to see you're online... I've been sifting through the electrical issue posts and finding a lot of situations similar to mine. My 01 A4 horn and turn signal won't work... fuses are fine. Seems related to the steering column, because horn works ok when activating the alarm. Maybe a relay switch? Are you aware of any electrical schematics online or have any ideas? Thanks as always!
Old 03-04-2005, 01:50 AM
6th Gear
do your hazard lights work? I'm not sure if the two problems are related or not. i don't have a schematic for electrical.
__________________
2004 VW Touareg
2005.5 Audi A4
Old 03-04-2005, 01:55 AM
Yup... hazards are fine. Everything else electrical seems ok...
Old 03-04-2005, 08:32 AM
It will take me a few minutes to look things up. In the mean time, why don't you spary some contact cleaner on the turn signal switch and see if there is just gunk in there
2000 horn relay in in the relay box unker the driver side knee bolster. It should be the relay number 1, he one farthest to the left.
Don't have info for 2001.
__________________
2007 A4 2.0T quattro tip
Nothing upgraded yet
Consumes Oil
Bluetooth Dodgy
Old 03-04-2005, 06:34 PM
Thanks! Probably not a difference btwn '00 and '01 horn relay. I'll check it out...
Old 03-08-2005, 03:10 AM
Default RE: How can I test a turn signal relay for function/failure?
I have the SAME problem on my newly purchased 01 A4. The hazards will work
but if I try to put the blinkers on left or right they wont go on! Every few rides though
they actually do work for a second..... weirdest thing! Any idea whats wrong? Horn does
work fine.. hmm?
Reply
Tags
509, 8d0, 941, a4, b5, dont, failure, hazard, pa6gf30, relay, signal, signals, switch, test, turn, vw, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
New Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
© Internet Brands, Inc.
Emails Backup
