How do you reset the service interval?
RE: How do you reset the service interval?
1) Insert your key into the ignition.
2) Push in the odometer reset button, hold it in, and turn the key to the first click.
3) The display should read either "oil" or "service" if it does not, repeat steps #1 and #2.
4) To reset, pull out your instrument light dimmer button at the bottom of the tachometer.
5) Turn the ignition to the off position. When the ignition is turned back on, the display should be back to the trip odometer.
There are two buttons on the display.
Left - I am assuming to be the dimmer switch. Also when pressed the message "next service in 10000" appears.
Right - Odometer reset button. When pressed the trip measured reset to 0.
Am I correct in my assumption?
