How much it cost to replace the timing belt?
I have a 2002 Audi Q3.0, and I think it's about time to replace timing belt. About how much does it cost to replace a timing belt? and where do you recommend get the service done and preferred at a low price?
Thank you.
BTW, what's a good sign indicating that it's time to replace the old timing belt?
Thank you.
RE: How much it cost to replace the timing belt?
Around $1,200 a the stealership, $650 to $750 using an independent mechanic. Do it between 60K and 90K mi.
http://1.8T.org
www.audifans.com
http://1.8T.org
www.audifans.com
Yeah front bumper and peal to the side the radiator. Its a huge task, definetly a long job 8-10 hours is about correct when I did it. Parts for me were about $320 which included tubes, belts and water pump. Best to do them all since your in there anyways.
8-10 hours? Yeah sounds about right for a first time job. I can do it now in about 4 hours. But the first time I did it I took my time and was careful. It's not a HARD job, just a time consuming one.
4 hours? that doesn't sound realistic... anyone I talked to said it will take at least 6 hours.... even the dealership and this guy that specialized in Audi said it will take a good 6 hours....
I guess you must know every bolt really really well to be able to do it in 4
It costed me 250 buks, and there is no need to take off the front bumper, I removed nothing passed fan. be a litle crampy but its managable.
took me 6 hours with a break of 2 hours on between for my daily cartoons. so like 2-work 2 cartoon 2 work. really easy considering I never done it before.
my mech wanted like 400-600 for labor to do it.
