Sponsored by:
Sponsored by:
How to reset computer
Old 11-21-2006, 12:51 PM
kwoodkayaker's Avatar
Default How to reset computer
Quick question,
Can I reset my computer on my own? My engine light just came on and I want to reset it to see if it returns. Its a 2000 A4 1.8L Q
Thanks
David
Old 11-21-2006, 01:01 PM
CRAZYHAWK's Avatar
Default RE: How to reset computer
Search for "Steve Hall VAG-COM Locator".
Old 11-21-2006, 01:05 PM
you could pull the negative lead on the battery and leave over night or do the same but turn on all the aux systems to deplete the memory what reason do you require this information??
Old 11-21-2006, 01:17 PM
Amze's Avatar
Reconnect your battery, just know it will reset the entire car including time/date and the radio... Typically
Old 11-21-2006, 01:24 PM
S_R_N83's Avatar
The best way would be go to Autozone and ask them to read your car and clear the code. If the code comes back, then you know you got a problem.
or... get a vag com
Old 11-21-2006, 01:25 PM
Yeah it gave me P1128 code 3 weeks ago and went away a day later, It just came back on again. I bought the car 2 months ago and just replaced the upper control arm last night. The car is performing the same way it was the day I bought it and all the post on the P1128 code were not promising. So I want to clear it and see if it returns. Any ideas or opinions?
Old 11-21-2006, 03:07 PM
CRAZYHAWK's Avatar
17536 P1128 Long Term Fuel Trim mult., Bank1 System too lean
If you have a 1.8t , check the L shaped vacuum hose between the G-12
reservoir and the intake manifold.
Old 11-21-2006, 03:42 PM
English? where did the 17536 come from and could you be a bit more descriptive. Any rescources or good reads for me. I have only opened the hood on a audi 3 times in my life and it looks a bit different than my wrangler.
CRAZYHAWK Date 11/21/2006 12:07:39 PM
Old 11-21-2006, 04:13 PM
S_R_N83's Avatar
ORIGINAL: kwoodkayaker
You were already given ideas.
You can disconnect the battery
You can find someone with a Vag Com and clear it
You can have Autozone clear it
You can go to the stealership and have them do it
Old 11-21-2006, 04:38 PM
Yep I saw those ideas, just responding to another questions, but thanks for reposting those, I am sure it will help others in the future with the same question, you could write the cliffnotes to every post if you feel like it.
avant80@2.6 what reason do you require this information??
ORIGINAL: S_R_N83
Quick Reply: How to reset computer
