jackstand placement
RE: jackstand placement
I think it's well referenced in the manual, but IIRC, it is just behind the front wheels or just in front of the rear wheels (depending on which end you want to jack up). Both sites are about 6 inches away from the wheel wells. They have a cross member that attaches (welded) near the same spot. They are referenced by two button sized "nodules". Whatever you do, don't lift at the thin edge of metal that projects downward along the bottom of the car (set in about 3 inches) unless you have a jack that specifically fits that lip - you will damage the car if you jack it on that lip with the wrong jack.
