Sponsored by:
Sponsored by:
my door wont open
Old 08-02-2005, 02:42 AM
phil9922's Avatar
Default my door wont open
i have a b5 a4. the rear passenger side door was working fine but now it wont unlock, and i cant get it open. i cant even unlock it manually, anyone know how i can get it open and fix it?
Old 08-02-2005, 03:09 AM
lidonnit's Avatar
Default RE: my door wont open
When you lift the hand does the button move at all?
Old 08-02-2005, 05:57 AM
EvilA4's Avatar
Safety first...
Old 08-02-2005, 07:08 PM
phil9922's Avatar
when i pull the pin up manually it doesnt move. when i press the switch, it goes up about 1/8 of an inch.
Old 08-03-2005, 04:34 AM
lidonnit's Avatar
You don't have the child lock on or anything do you? Although it should still open from the outside but it may be jammed. If you are certain it is a door problem not an operator problem (no offence). Then I would take it somewhere to get Vagged & see if there is an error code coming up. I don't even know if our doors put out error codes? Anyone?
Old 08-03-2005, 09:36 AM
david9999's Avatar
The central locks put out codes.
euroimport88
04-07-2010 12:23 PM
fromzerophreak
11-07-2009 02:12 PM
540guy
02-05-2009 08:22 AM
myownstylett
05-29-2008 04:06 PM
Antonio8
11-23-2007 09:16 PM
Quick Reply: my door wont open
