Sponsored by:
Sponsored by:
need help with codes
Old 06-27-2007, 09:53 AM
rafa_207's Avatar
Default need help with codes
I got p0303 cyl 3 missfire
p0302 cyl 2 mis
p0300 ramdom mis
p1176 bank 1 sens 2 cat efficiency
p0133 bank 1 sens 1 singnal too slow cat efficiency
I dont have a catalitic converter and yes I already did the non fouler mod also car now wants to turn off when im driving ...
Old 06-27-2007, 10:29 AM
onepoint8tee's Avatar
Default RE: need help with codes
You have a misfire(s) Since you have cyl 3 and cyl 2 misfires, swap the coil packs from 3 and 2 with 1 and 4. Clear the fault codes, drive, if/scan forcodes again. If you now have cyl 1 and 4 misfires, its bad coil packs. The sensor 2 cat efficiency code is probably from not having a cat, and the sensor1 code is probably a byproduct of the misfires. Please list your year/engine type when asking questions! If after you try all that^ you still get cyl 3 and 2 misifres, your ICM is probably shot if you have a 97-99.5 model.
Old 06-27-2007, 01:31 PM
acetrebo's Avatar
Yeah, whats the year and engine for your car?
luefher
02-16-2012 06:44 PM
markymarc
09-08-2010 01:59 AM
joenelson7687
08-25-2010 04:10 AM
Ruggedboy
07-20-2007 11:30 PM
supercoupe91
07-13-2007 06:20 PM
Quick Reply: need help with codes
