Sponsored by:
Sponsored by:
lags at low rpms!
Old 06-07-2006, 07:20 PM
polanco's Avatar
Default lags at low rpms!
im a new audi owner dont really know to much but i feel that it lags in low rpms. like when i take of its slow intill it hits like 3,500 rpm. then it takes of is that normal??
Old 06-07-2006, 07:22 PM
Dj Spiel's Avatar
Default RE: lags at low rpms!
Would help if we new what car you are.
new car--- 1st i suggest
Oil Change
New Spark plugs
Rotate tires
**basic stuff 1st**
2.8L or 1.8T???
Old 06-07-2006, 07:25 PM
a4sport's Avatar
He soved it himself if it's a 1.8T.
Old 06-07-2006, 07:34 PM
onepoint8tee's Avatar
Probably turbo lag if its a 1.8t.. I assume that you are just roughly speaking because the turbo lag on a k03 is extremely minimal. It shouldnt lag past 2k rpm or so.... At least mine doesnt. If your AC is on, that will give you more noticeable lag in the 2500-3k rpm range.
Old 06-07-2006, 09:39 PM
sounds like turbo lag to me
Old 06-07-2006, 10:31 PM
18T's Avatar
18T
18T is offline
ORIGINAL: Dj Spiel
2.8L or 1.8T???
why would you even ask that? ofcorse he has a 1.8T.. its called Turbo lag
Old 06-08-2006, 01:31 PM
sandnsnow24's Avatar
the 2.8 12v does it too surprisingly. It's just how the engine is built i guess. at least mine does
Old 06-09-2006, 06:43 PM
polanco's Avatar
yeah its a 99 1.8t so it might be normal. well i dont know to much so im trying to find out thanks
Old 06-09-2006, 09:00 PM
AHB900's Avatar
mine does that too its just if ur in the wrong gear like u get into 2nd to early ur turbo needs time to spool up u kno... its turbo lag.......
Old 06-14-2006, 02:29 AM
polanco's Avatar
so is it normal to do that or is there something wrong. is turbo lag normal....
Quick Reply: lags at low rpms!
