Polished Throttle Body and clean ICV
Just got finished with a little two day project of cleaning my Idle control valve and polishing my throttle body to a GLASS finish.
It completely fixed my idle problem and the polishing of the body makes the power band seem smoother alllll the way through, no lag in response anymore. Not a big change, but nice none the less
Here are some pics:
Here are some pics:
RE: Polished Throttle Body and clean ICV
ya i think just cleaning it out did the most, but i like to think my car is running better with it polished
i'm not on my comp but i had a guy send me a diy form another site, i'll post it up for ya when i get home.
didn't take to long, i just took my time and it was prolly total 5-6 hours. the time intensive part is actually polishing the body. I used a dremel "polishing stone", but i talked to my dad today who said scotch bright is what his porsche shop uses to polish intake manifolds, my next project
nice job on the tb. to bore it out bigger you can use magna steel and form it on the out side and then open up the whole opening of the small side. i am also planing on doing my IM they say it is a very long job. when you do the IM you will need a die grinder to do the job it is made out of aluminim nickel
what did you use to cleen the icv. i need to do that it is causing my almost stalling prob
i just used carb and choke cleaner and you spray it inside the two open holes then pour it out. I did it like 20 times jsut to make sure ti was clean.... don't use it to wash your hands though like i did..... it's a bad idea trust me [&:]
a4_2.8tuner
05-03-2011 08:09 PM
pas6201
06-11-2008 07:19 PM
