Sponsored by:
Sponsored by:
removing knee panel under steering wheel
Old 07-18-2007, 08:12 AM
viper_04649's Avatar
Default removing knee panel under steering wheel
I have a 99.5 A4 2.8. I need to remove the panel that is under the steering wheel to get access to run some stereo wires. my problem is the two bolts on the front, under the covers. I have tried 6mm, 8mm, and a few english size allen wrenchs, all to fail. What is this bolt? What can i use to remove it?
Old 07-18-2007, 09:43 AM
akielb's Avatar
Default RE: removing knee panel under steering wheel
10mm or 8mm socket can't remember - its not an allen head
Old 07-18-2007, 03:28 PM
they didn't look like sockets, they are round and have a hex hole. It almost looks like a button head screw with a really shallow hole for the tool.
Old 07-18-2007, 03:38 PM
its sort of a hex screw with an expander, remove the screw first ( its plastic )so is the expander
Old 07-18-2007, 03:40 PM
ORIGINAL: avant80@2.6
I don't see anything that is plastic, i pull away the plastic cover, and there is just a metal screw.
Old 07-18-2007, 03:45 PM
onepoint8tee's Avatar
The bolts that hold the knee pannel on are regular socket type. Im 110% sure on that. They arent hex/allen type. Can you take a pic of what youre talking about exactly. I think what you and I are calling the "knee pannel" must be 2 different things.... Somehow...
There are also 2 or 3 bolts on the side of the dash behind the fuse pannel cover that need to come off to remove the knee pannel.
Old 07-18-2007, 04:02 PM
the bolts i am talking about are the ones that would be right next to your knees
the screws under these covers
Old 07-18-2007, 04:03 PM
Yeah they are regular bolts.. I dont remember the socket size, but it is a regular metric socket. If I remember right, they are at a funky angle, and getting a grip on them is not exactly easy.
8mm socket if I remember right
Old 07-18-2007, 04:13 PM
akielb's Avatar
only thing that I can think of is the previous owner removed it and replaced the bolts with new socket heads. the bolts on the side by the fuse panel are the same size.
Quick Reply: removing knee panel under steering wheel
