08-21-2006, 06:46 PM
Rubbing noise from steering wheel
Hi,
I've recently noticed a rubbing noise coming from the steering wheel. Doesn't sound like anything to serious but is very annoying. Sounds like plastic rubbing somewhere near the top of the column. also getting a creaking noise when I turn the wheel slowly. However, this only lasts for about 10 degress in each direction.
Anybody got any ideas on this?
Regards
08-21-2006, 07:34 PM
Level up: 4%, 193 Points needed |
RE: Rubbing noise from steering wheel
Spray some white lithium grease where the rubber parts meet. This is in the interior , into the steering column.
__________________
2009 Subaru Impreza 2.5i Auto 4dr Premium
Previous Car
2001 A4 1.8T Q Casablanca White, Tip, ESP, Xenon and Premium
08-21-2006, 08:08 PM
Maybe you are hearing your power steering pump, check your ps fluid level.
__________________
97 A4 1.8TQM
garrett t3t4 50 trim
Megasquirt on 630cc injectors
08-21-2006, 08:17 PM
check all the above but concentrate on where the noise is emanating from ( is it the height adjustable steering wheel ) does it need checking
08-21-2006, 09:03 PM
same problem i had a few weeks back...like ^ said spray some grease around the bushings, fixed mine! I took it into the shop they said was play in the tierod end that was making the noise.
__________________
2K1 - AWM - 1.8T - 4X4 - Stick - Bose - Igloo Package
Unitronics Tuned / Forge 007 / K&N Cone / FMIC / Straight-piped TBE / Debadged / 18" RS4 / Falkens / Ostalbkreis / Panzer / VDO
Tags
2001, 2006, a4, audi, column, grease, lithium, makes, noise, quattro, rubber, rubbing, steering, wheel, white  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
