Seized the engine?
#21
RE: Seized the engine?
dude u are a d-bag,......sorry i had to, so at what point did u think that ur engine would run with no oil.......u didnt even think it was bad when u could hear ur engine melting together???????/?[sm=pcwhack.gif]
#22
^^^^wow and you say I was harsh djspiel. I really do hope your engine turns over and runs after you try all those methods, but if it does, you just took many years off its life. On the other hand start looking for a cheap replacement, try the salvage yards, ebay, local shops, wherever. Goodluck.
#27
Well its hard to tell if it will even work again but If and i say IF it does start again id say that it wont last much longer beings as how you made the motor so hot that it tried to weld it self together and stop running...... id say dont expect more than a few thousand more miles
#28
oh and also when you sieze a motor and get it that hot it scores the cylinder walls, and IF you get it to run again by chance.... it will burn do much oil that you could be hired to fog mosquitoes and then the other thing is that it depends what siezed the cylinders or the bearings, cuz if its the bearings its done no matter what
#30
well at least alot of new parts.... if you seized the pistons in the cylinders you will need to have the block bored out, and get new pistons, rings, bearings and all the other lil things to rebuild a motor.... now if its the bearings you will have to have the crank ground, new bearings, hopefully the pistons arent fucked, and all the other lil parts
Either way its gunna cost you at least $2000 which is just my best guess
ORIGINAL: AnIdiot
So basically, no matter what, I need a new engine.
